Deleted member 7876
Firstly, thanks to all for your help and advice with the radiator fan problem.
Next up (more water problems)
Our Moho has a Carver Cascade water heater, it IS filling and the water is getting HOT.
Strangely though, the hot water supply to the kitchen sink mixer tap is just a trickle when opened, the pump is running and water comes out, but a not a lot.
The cold on the kitchen sink mixer tap works as it should.
The feed to the shower tap in the toilet is working as normal , hot and cold both under pressure.
What could the problem be.? There's no damage to the pipe that I can see and there's no leakage either.
