lpg false fail ?
rugbyken
the last night at hollingsworth i thought i had run out of gas got up in the morning couldn’t boil a kettle ! i have 2 x 11kg gaslo normally run with one turned off so turned on second still nothing thought i must have got it wrong way round i’d had 3 days at will o nats with a bit of heat and 4 days constant at hollingsworth , on way home called in at three morrisons all out of lpg tried the gas lo head office in loughborough closed for bank holiday ! when i reached home noticed the fridge running on auto gas ! tried the rings all running ? went out today filled up at the flo gas depot blackbird rd leicester 79p a ltr only took 22ltrs ? wondering whether a blockage or stuck valve will run them in reverse see whether the normal second bottle works ok
did think of it waxing up but not seriously cold and heating had been on all night , & mix should be right given i last filled up in scotland in oct lol
Where are we to get lpg on our way to Devon and Cornwall now😭🥴
D&N Autocare Flogas 22 Knights rd Chelston business park, Wellington, TA21 9JH 018230668668
24HR IF YOU HAVE A FLOGAS KEY
Just phone them 99p ltr
LPG Autos. N1 Tregath Business Park, Camelford Station, Camelford, Cornwall. PL32 9TX. 01840 211443
I’ve always found the guy here very obliging 😀😀
Whilst this should not (still) be the issue, there was a period of a few years when the quality of LPG hose was suspect, and degraded the internal hose causing blockages of the hose and or regulator too.
I understand some garages are removing LPG pumps, Shell for sure, usually by taking them out of service as their vessel certification goes out of date, (10years) the cost of recertifiying being a hefty sum. For some years in the 90`s I carried out a lot of work for Calor, and the time and work involved with examination, including gas freeing relief valve testing/refurbishment is expensive and needs to be recouped out of profits.
P.s.. For anyone in the Newark area, Brownhill`s did have an LPG filling facility, at least up to 2019?.
Pete
