My Self Build
My Self Build
I have a lot of pics of my build so ten a day or the forum will fall over.
I farmed out the back windows, it was only £20 more than DIY, and I learned how it was supposed to be done from a pro, remove sole plate and down use tape, slow and steady, did them all the same way cut the servies holes like that too.
Please ask any questions as the thread progresses and I'll do my best to answer them.
003 Bonded windows.JPG004 bonded windows.JPG005 bonded windows, they use a Jigsaw, but remove the sole plate, they cannot afford to have a...JPG
  • 002 bonded windows being fitted by the pros in Castleford, so I could see how they do it.JPG
008 Windows Near side.jpg009 Windows offside.jpg010 heki 2 fitted prior to the spray foam.JPG
011 heki 2 inside.JPG013 Outside of Heki2.JPG014 inside near side rear window, the two struts are NOT structural,  and are simpley to stop ...JPG016 Cut SLD rail to line to allow fitting of NSR seitz window.JPG017 Rough cut done - see Seitz corner hole.JPG018 018a Phew it fits with 1mm gap all round, bad pic, difficult to see but the TOP is written...JPG019 25a oops blind wrong way up.JPG
  • 015 prior to drilling corner holes, struts gone, note squares used to keep frame square.JPG
  • 012 showing removed roof rib at joint to allow fitting of Heki 2,  just fits nicely.JPG
I don't seem to be able to add any text to the post, if I do it first it puts it at the bottom, and can't add any between the pictures to explain them, also almost all have a description in the file name, any way see that?
Having previously built a car I recognise just how much effort went into your build, Kev. What software did you use for the schematics?
I remember lying on my back in the tub as I completed the wiring loom, finalising and testing connections. I couldn't do it these days as my back isn't up to it.
Very well done on a quality build, and I look forward to seeing any further photos.
I used a online program called floorplanner first, but it wasn't good enough as it was meant for houses, if you could see the file name it would tell you it was Libre open office.
I think I may try a different way to show them so I can give info on each pic if needed, this way is frustrating.
Know what you mean about back, I have deteriorated badly since doing the build, couldn't do another one :( :(
021 I used this section to make a new SLD hold back for new door position. After shortening the central slider rail, it needed a new stop at the bottom, this section when cut off and bent a little made a the perfect piece to stop the SLD hitting the open Seitz window.
021 I used this section to make a new SLD hold back for new door position.JPG
022 26 Inside of SLD showing window hole, note strut is cut right back to allow the inner frame to fit.
022 26 Inside of SLD showing window hole, note strut is cut right back to allow the inner fram...JPG
023 26a SLD hole showing incorrect marking out, window would have been 25mm to the left of center OOPS nearly. Proving measure twice and cut once works well.
023 26a SLD hole showing incorrect marking out, window would have been 25mm to the left of cen...JPG
024 26b SLD window hole cut, need to tidy up the mess in front of the garage.
025 26d SLD inner frame and blind right way up this time, note copious use of red lead paint, it's a 250ml tin, so use plenty of it, you have more than enough to do ten vans
. 025 26d SLD inner frame and blind right way up this time, note copious use of red lead paint, ...JPG
This way works, but I have to add each picture individually, and also the file name.
Is there a better way Phil???
026 down nearside showing both windows and modified SLD rail, with end cap painted and replaced properly, could maybe have removed 10mm more.
026 down nearside showing both windows and modified SLD rail, with end cap painted and replace...JPG
027 28 using frame to mark out hole for omnistor 3 speed two way fan
028 29 Omnistore hole cut filed and red leaded
029 29a Omnistore outside - not good on the knees this roof cleaning
030 29b Omnistor fitted minus internal cover
031 34b Trunking NS, note the use of T junctions with cover plates, get plenty and use them, remember where they are for later when you fit the wires you forgot about
031 34b Trunking NS, note the use of T junctions with cover plates, get plenty and use them, r...JPG
032 34b Trunking OS
033 34c Trunking over rear doors for camera and lights
034 37 Looking down on floor 18 inch centres at rear, red lead on anything which even looked like it might rust
034 37 Looking down on floor 18 inch centres at rear, red lead on anything which even looked l...JPG
035 38 Roof battens held in place with screws and Stixall, I wet them and left them suspended between two bricks for a week, with brick weighing down the centre so they took on a curve, once dried out I fixed them up.
035 38 Roof battens held in place with screws and Stixall, I wet them and left them suspended ...JPG
036 36 Heki masked for spray foam - tip use double sided tape
037 39a spray foam being done by Andy at MPI in Bolton
038 39b spray foam
039 39c spray foam, arches and floor did get sprayed too
040 40A Solar panel rear showing mounting plates
041 40B Solar panel rear connection box
042 40C Solar panel spec
045 45a Fresh water inlet partially cut, note no sole plate on Jig Saw.
046 45b Fresh water inlet hole cut, I did neaten it later, see thickness of spray foam around the hole. you can also just see the black mark left by the jig saw, had I used a sole plate the risk of paint damage would be much greater, as is, whatever the hole is for it will get covered up.
047 45c Fresh water inlet test fitted prior to sikaflex and final fit 047 45c Fresh water inlet test fitted prior to sikaflex and screws.jpg
048 49c water inlet inside, and messing about in my corner with sparky stuff
049 44a 240v inlet hole marked out and ready for jig sawing
050 44c 240 inlet hole filed smooth ready for inlet fitting 050 44c 240 inlet hole filed smooth ready for inlet fitting.jpg
051 44d 240 inlet finished outside and fitted
052 44e 240 inlet from inside
053 46a Original position for 2 x 125ah LBs off Ebay £150, but found that with minimal effort they would fit under the driver or passenger seat 2013-04-12 16.46.06
053 46a Original position for 2 x 125ah LBs off Ebay £150, but found that with minimal effort...jpg
054 46f I tried them under the drivers seat even though it looked tight, the seat springs did not come anywhere near the posts despite how it looks, and I had a 3mm plastic sheet above just in case. 2013-04-12 17.03.40
054 46f I tried them under the drivers seat even though it looked tight, the seat springs do n...jpg
055 46g with a few mods to the underseat harness they fit easily (see 053 for model) 2013-04-12 17.04.34
055 46g with a few mods to the underseat harness they fit easily (see 053 for model) 2013-04-1...jpg
056 put wires into a split piece of 42mm plastic waste pipe , shove them forward enough to drop the LBs in which holds them in position, it's a tight fit, need 10mm batten to level LBs
056 put wires into a split piece of 42mm plastic waste pipe , shove them forward enough to dro...jpg
057 see spreaders moving harness forward, to be held in place with split 42mm pipe, cut a third out of the diameter along its length, and the LBs hold them in place 2013-04-13 13.11.00
057 see spreaders moving harness forward, to be held in place with split 42mm pipe cut a thord...jpg
058 I moved these from B pillar base to under the drivers seat for easier access after the build, wires are long enough as is, I also solved the draught problem while I was at it, and I did the nearside later 2013-04-13 10.19.31
058 I moved these from B pillar base to under the drivers seat for easier access after the bui...jpg
059 Electrics to be moved from B pillar base to alongside the LBs under the drivers seat for later access if needed, I believe they are for the seat belt
warning lights 2013-04-13 10.20.19
060 Gubbins behind the drivers side step plastic cover, large plastic box is the sat nav thingy from Citroen, it never worked, but I
left it anyway. 2013-04-13 10.22.53
062 47b after spray foam 2013-04-21 15.59.36
063 47c after spray foam, corner moldings etc up out of the way, but easy to get at later 2013-04-21 15.59.44
063 47c after spray foam, corner moldings up out of the way, but easy to get at later 2013-04-...jpg
064 47d after spray foam and over cab locker before wrapping, it took a little time to get it right on the cardboard template, but it was my first one so fairly happy with it 2013-04-21 15.59.58
064 47d after spray foam and over cab locker before wrapping, it took a little time to get it ...jpg
065 47e this is my step ladder, but I really miss my real ladder, forward batten was about 10mm to far forward rubbish planning there 2013-04-21 16.01.40
065 47e this is my step ladder, but I really miss my real ladder, forward batten was about 10m...jpg
066 48 first ceiling panel 2013-04-26 13.44.56
067 49a hokey cokey back board temporarily in place
068 49b and out again to do more wiring
069 49d some more cable run and back board tempo in place to cut slots
070 49e make yourself a BIG square and check it often, you cannot rely on a spirit level when you are moving around inside the van, Roofing square was invaluable too, see solar reg in place for the first time, and holes below for cabling
070 49e make yourself a BIG square and check it often, Roofing suare was invaluable too, see s...jpg
071 50a solar temp mounted, first 4 of 6 holes drilled 2013-05-03 15.24.57
071 50a solar temp mounted, first 4 of 6 holes drilled 2013-05-03 15.24.57.jpg
072 51e the SCARIEST part of the build really, the hole for the loo cassette door opening 2013-05-07 15.35.18
072 51e the SCARIEST part of the build really, the outside of loo cassette door 2013-05-07 15....jpg
073 51c inside the cassette door hole, showing temp timber in place, the pipe you see is a waste pipe for running
cables through later 2013-05-07 15.25.47
073 51c cassette door hole, showing temp timber in place of wall 2013-05-07 15.25.47.jpg
074 51g Start of boxing, note use of KD connectors, we like them a LOT, you can also see the first positioning of
the LB Ctek 5 amp charger, it was moved later on
074 51g Start of boxing in 2nd attempt to make it look better, note use of KD connectors, we l...jpg
075 51f with door surround temporarily in place till Stixall goes off 2013-05-08 12.49.27
075 51f with door surround temporarily in place till Stixall goes off 2013-05-08 12.49.27.jpg
076 52b back to sparks, see tidied up terminals with heat shrink sleeving, I was a bit annoyed that there was no
cover for the bottom to hide ugly wiring, or an option to come in from the rear, ooer Mrs 2013-05-15 16.50.40
076 52b back to sparks, see tidied up terminals with heat shrink sleeving 2013-05-15 16.50.40.jpg
077 53a Controller, Switch panel and Volt meter, left switch on control panel controlled which battery you saw
displayed on the volt meter below VB or LBs, I looked at lots of switches, and found this (Zig SP-4)
the simplest to use and mount 2013-05-15 16.50.29
078 52a I ended up moving these, Ctek fitted, B pillar cover on, wall up, filler pipe access hole,
now moved to below in a sparks box see other pics 2013-05-10 11.07.42
078 52a I ended up moving these, Ctek fitted, B pillar cover on, wall up, filler pipe access h...jpg
079 56a new place for inverter, Ctek charger, and water inlet looking down between driver
seat and bathroom wall, see later pic when finished
079 56a new place for inverter, Ctek charger, and water inlet looking down bathroom wall see p...jpg
Very nice well done,just two points,first wires coming through at side should either have grommets or a length of garden hose to stop chafing,second why not cut the plug of charger and feed from fuse trip box saving you all that plug /socket stuff.
I have one of those ehu side inlet boxes and it let water in like mad through the back hole,do cut a drain slot at bottom of outer door so if any gets in it will just run out again,flooded my carpet on pas side.
Also wanted to ask about the seitz window as i have one,where do you get the side top bottom infil to hide screws.
Which wires are you referring to please? I always use proper grommets, hose pipe is a poor substitute.
if I had cut the charger plug off it would have invalidated the warranty, and it worked fine that way, it could also be easily removed to charge the VB if required.
the 240v inlet was sealed around the outer surface, these are a very old design, tried and tested for decades, so I don't know how yours came to leak.
the screw covers are called perforations, order from a caravan dealer, you need the S4 size code off the window pane, or S5 if the concertina blind type.
I cannot find them anywhere, annoying as I bought some 3 years ago, either leisurespares or leisuresparesdirect. I assume it's the S5 you have with the concertina blinds, you need the ones similar to this https://www.ebay.co.uk/itm/Seitz-he...419107&hash=item283757b033:g:4jIAAOSw-7RVFtIf
the S4s have a simple bung https://www.ebay.co.uk/itm/Set-of-t...g-screws-and-screw-covers-SBSC2-/182603343975
080 loo n tray in place to see if the heater hoses would fit, but ended up moving to the other side of tray to accommodate the electrics behind loo wall, I should have left them there 0130512_113433
080 loo n tray in place to see if hoses would fit, but ended up moving to the other side of tr...jpg
081 54a First ever wallboard template cut done, scary at the price of them, so I scribed direct to a 3mm ply template, it fitted
like a glove
082 54b Top of ply template, I used cardboard as it easier to mess with and
I found there were differences in the vans metal roof height
083 54c Just add bits using double sided tape til its a snug fit, then transfer it to the lightweight ply
083 54c Just add bits til its a snug fit, then transfer to the lightweight ply.jpg
084 55a then take a very large breath and cut your first expensive sheet, PHEW, outer front loo wall in position 084 55a then take a very large breath and cut your first expensive sheet, PHEW, outer front lo...jpg
085 55b nice snug fit, you can see the u shaped plastic track which holds the wall in place,
I found some matching beige silicone to seal the track to the board,
this board was a cheapo paper faced ply, So I got some aerosol cans of stain lacquer
made up and I sprayed each board to waterproof it, never saw any marks on them
086 55c other side of wall in 085 shows control panel, solar reg and volt meter for VB looks weird but it is straight.
You can see to the left the blue carpet covered overcab locker, I never did put a door on it, but nothing ever fell out
086 55c other side of wall in 085 shows control panel, solar reg and volt meter for VB looks w...jpg
087 57a shower tray side supports, I have read of so many problems with
shower trays cracking I did my best to make sure this £27 one didn't, it is still
100% watertight
088 57b shower tray bottom support fully bonded to base with Stixall no way this is going to flex and crack,
I offered it up to the floor in position, and drilled through with a 300mm long drill both waste positions,
as it turned out one was directly over the chassis so couldn't be used, so one got welded and just to be sure
stixalled it too never leaked to my knowledge
088 57b shower tray bottom support fully bonded to base with Stixall no way this is going to f...jpg
089 58a back side of shower and left side of wardrobe decorative ply in situ, holes are there as this is where the
main fuse board will be located later and the back ply is the back of the fridge housing, a lot of work there,
and more to do yet, top fridge vent to figure out and cut, bottom one already done,
this was to fit a full height fridge freezer, pump was later moved, wish I left the heater piping where it was
in the earlier picture, see the kinking, I'd not accounted for the width of the corner profile, fortunately this part of
the pipe only went to a vent facing the back of the driver seat, as I sit up there a lot reading and watching the
world go by so wanted heat when parked 2013-06-14 11.44.43
089 58a back side of shower and left of wardrobe and back, the ply is the back of the fridge h...jpg
091 62a Truma E4000 in place on it's original plinth, now moved to outside wall on right,
as it was a better use of space 2013-06-15 17.39.45
091 62a Truma E4000 in place on it's original plinth, now moved to outside wall on right bette...jpg
  • 083 54c Just add bits til its a snug fit, then transfer to the lightweight ply.jpg
  • 089 58a back side of shower and left of wardrobe and back, the ply is the back of the fridge h...jpg
