Dahlia duo
Hi molly 3Could help if you posted your system
P. S. The panel is showing the state of battery’s and working as it should, but if you bush over to vehicle battery it’s shows the battery state, where it should read 13.1 or there aboutsHi molly 3
The system is a sergeant pu o7 ?
When hooked up to electric it is charging the leisure batt but not vehicle battery
Sounds like the same as my 06 Autotrail. The vehicle battery doesn't charge from that if it's under 11. I use a separate battery charger with clips direct onto the vehicle battery for an hour or two, then run the engine for an hour. I have to check/charge my batteries every weekend at the mo.Hello
04 Kon-tiki with control panel above the the door, touch top left button to switch on electoral supply, the button next to it (top right) once pushed let’s you change the vehicle battery when you are on mains hook up. This is not happening
Anybody had the same Problem??
Oh ok, well my charging checks aren't that exact. I'd kinda think it had done enough at that stage. I'll leave it to better qualified responders nowHi Beatrix
thanks for reply.
ok let’s start again. My leisure battery is 12.2 and vehicle battery is 12.8. So no problems there. When I hook up to power the leisure reading go’s up on gauge, when I cross over to vehicle battery it should go up too, normally 13.1 but it is not doing so. Telling me it’s not pushing a charge over. That’s the problem I have.
hello markbSo the EU charger operates - which means that it should do the starter battery when you switch over.
This answers my second question but Q1 was to confirm that the switchover works - I.e. can you run had electrics off the starter battery?
If you can't then you have a duff changeover which would explain the lack of charge.
If you can then you'll have to check the charger wiring.
All batteries should show around 12.7 without charger on, with charger 14.4v and drop to 13.7 ish on float.Hi Beatrix
thanks for reply.
