No Power in Living area
Madmonk
Hi ,I have a flash Chausson 08, I have tried to activate the power in the rear ,it will not turn On, checked fuses and battery all ok , help please
As above, 30/40Amp fuse about eight inches from leisure battery. Whilst there check pos and neg terminals are secure.
Also make sure ignition key is off.
When did you last use it ? Please take this the way its meant but do you know you've leisure battery as well as a engine battery
Have you fired up the engine..?
It could be a sticky relay, if it's been stood a while.
Good luck.
Is the battery charged?
My van has a rocker switch on the control panel which up, selects vehicle battery. Middle, isolates both batteries. Down, selects leisure battery.
Has your panel got a battery select switch? If so can you try if power is present when vehicle battery is selected.
Also check if switch is not in isolation position.
Some of the Chausson vans have a battery control unit that takes the power from the starter and leisure batteries and switches it for the main power input and is the split charge system. This unit has four fuses in it. Here is a picture of one posted by a member of wild camping.
