Scotia
Spent today removing the rear pod to sort out an electrical problem with having no rear lights, and no near side front side light. Tried all the fuses no go, removed all connections gave a clean no go, finally removed the rear valence to remove a light unit that i knew was corroded but had already previously purchased a new unit. Once this was fitted i went from only having brake lights to only rear lights then both brake lights and one rear light.
I bridged the offside rear light to near side the lights dimmed then brake ( i had a stick onto the brake pedal) and rear illuminated i removed the bridging wire and everything was still illuminated. I then checked the side light which had fixed by itself ? I have removed any soldered connections and re soldered then heat shrink over the connection. I just wish i knew what i have done to rectify the problem, i have tried tugging wires just in case there is a broken wire under the sheathing but nothing is showing up. When i press the brake pedal both lights illuminate but the bulb out warning light comes on within the dash. Its got me!
