Hi 14Poynting Puck on the roof. Huawei mifi inside. For the latter make sure you get the version with antenna inputs. You will need to buy a pair of adaptors to convert the poynting plugs to the Huawei sockets. Cheap as chips on fleabay .
I have mentioned before on the other forum that my usual hunting ground for short and medium trips is around mid, south and west Wales where poor 4g is the norm once out of town. My setup makes the difference between receiving a signal or not. Currently parked on the coast near St David's where EE is very poor and 3 not much better. Anyway, took the 3 sim out of my dual sim phone, bunged a data bundle on it, popped the sim into the Huawei and now we can stream SD TV. That wouldn't have worked with a phone inside our metal box (aka van).Hi 14
what sort of improvement have you seen over phone only use?
I’m tied into Vodafone until next May. Hopefully this plan will still be available then. Usually these plans finish a couple of weeks before I go for them.You could watch this video:
Phil explains what equipment he is using,
Regards,
Del
Just done this today.Poynting Puck on the roof. Huawei mifi inside. For the latter make sure you get the version with antenna inputs. You will need to buy a pair of adaptors to convert the poynting plugs to the Huawei sockets. Cheap as chips on fleabay .
Yes, we've had a Wi-Fi booster for some years, but now that mobile data is much cheaper than before we rarely bother trying to pick up Wi-Fi. It was always a struggle anyway.Motorhome wi-fi '5G ready' roof antenna with Huawei router and Three SIM. Works really well in most locations, including on the move. We had the Motorhome wi-fi booster on our old van - found it didn't help much if the wi-fi source wasn't good enough in the first place (as is the case on many campsites...) So just went for the mobile network option on the new van - it's apparently what the ambulance service uses.
I think you will find that the emergency services use Cradlepoint routers, which are a bit too expensive for most of us- it's apparently what the ambulance service uses.
Your title enquires about Roof top WiFi most answers are about Mobile data which do you wantAny recommendations on which equipment to go for please?
SIM card?I have to order a 12v cable for the router and fit an other 12v cigarette socket in the cupboard .Del do you take your SIM card out your phone and put it in the router .?
