Phantom
My 2005 MH is pretty sorted to my liking now though feel that the leisure battery performance could be questionable but is probably not? Just using an LED TV for 4 or 5 hours can have the solar charger indicating that the leisure batteries are low. The solar controller is the type that the LED for battery charge state is either green, yellow or red, and flashing green for fully charged. Alternatively I can take a battery voltage reading via a cigarette lighter socket, usually shows 13.0 or 13.1 when charging well or fully charged, but is still not an ideal way to know your battery status so maybe I could do with some device that would accurately monitor and indicate the actual percentage of remaining battery power? Any recommendations welcome.
My current set up is a 120w solar panel with two leisure batteries rated 110 & 115 amps connected in parallel so potentially 225 amps in an ideal world. Just a few hours of morning sun or a drive will normally soon replenish the batteries from the previous night's use, so doesn't seem like they were actually that low? I added the second leisure battery just last year after the panel tripped out due to low voltage but when going to fit the new battery found a loose battery terminal on the original, I can't vouch for the original's health though but feel it is okay, and as it was already wired to take a second battery I just connected it up. I guess that I just really need a better battery status indicator that can measure power our and in? So what is good?
