TissyD
Good morning. I am having problems charging my leisure battery through the solar panel. I am getting a good reading from the panel, around 14 volts, but no output from the controller. It worked okay when it went into the garage last year to have the gearbox rebuilt but has not worked properly since. Those of you that were with us at New Year will know that Jeff took me to fetch a new battery so I know the battery is okay but I just cant get anything from the controller. Because the battery went flat while it was in the garage could the controller have tripped out, if so can it, be reset? It is a Fangpussen 3030
