gasgas
I've just become the 'proud' owner of a 1999 AutoSleeper Pollensa. It's on a Ford Transit (automatic gearbox with torque cconverter) with a turbo which looks half like it's an add-on (TB Turbos) and half not because some of the turbo air handling manifold has the Ford logo cast into it. I remember that a company called TB turbos was doing expensive modifications to standard engines, and a big market of theirs was motorhomes.
Anyway very strangely I have discovered that although I knew when I bought it that it had three batteries, it turns out that two of them both in the engine compartment are wired in parallel, leaving the leisure battery all lonely under one of the sofas in the hab area.
The mh has a BIG 200W solar panel, an MPPT regulator and a 2000W / 3000W peak mains inverter. The seller left all sorts of junk in it - knives forks spoons, plates, mains TV, mains kettle, mains toaster, hoses, wires and pipes which I know not what they are for, watering can and it wouldn't surprise me if I find a massage machine somewhere. It also has a diesel space heater - Webasto style. The original Carver one has been removed much to my displeasure. I think they were the best possible heater - no complex electronics, the only electrical bit was the sparky and thermocouple. What more do you want?
Anyway does anyone know if a 1999 Transit diesel turbo would have been built with two engine batteries? They are on each side of the engine on top of the wheel arches, each with a proper steel battery shelf to sit on. It's almost as if the Transit was a special version with two batteries for transiting the North Pole. The gurt great fat cable joining them has a Ford label and is properly, factory terminated at each end.
My inclination is to change the config to one engine battery, take the gurt great fat cable to the LB under the sofa and thus have two LBs in parallel rather than two engine batteries in parallel. I have never seen that since the days when I was trading London Taxis - the FX4 ones. They had two batteries, but they were two 6 volt ones, wired in series.
