UFO
Our power usage is quite light, around 20ah/day in winter and 15ah/day in summer (see attached), but as I could fit 2 x 125ah into the battery space I went with more than we need.
Never use EHU apart from a couple of hours before we leave on a trip.
I asked Alpha for recommendations for replacement, their reply ‘The batteries you have there have lasted well, I am surprised with this as the particular batteries you have there are not over-engineered for deep cycle use’. That’s probably because of the installed capacity and light use, so limited deep cycling.
120AH Leoch Adventurer flooded lead-acid (SFL-120DT) at £99.99 or the 130 AH version at £109.99.
Or
110AH Expedition Plus Lead Carbon Gel Ultra Deep Cycle (EXP12-110C) at £189.99 or the 250AH version at £389.98.
Prices before discount.
I am tempted to replace like-for-like i.e 2 of the 120AH Leoch Adventurer flooded lead-acid.
Any thoughts or recommendations?
Equipment
The original equipment, Adria Twin PVC first registered June 2009.
- Schaudt EBL208S Elektroblock
- Schaudt LT311 Control Panel
In April 2013 I installed
- Alphaline Plus Deep Cycle Series DC31 MF 12v, 125ah, (20HR) Sealed Calcium battery x 2
- 140W solar panel
- Schaudt LR1218 Dual Battery Controller (Pulse Width Modulation - PWM)
Recently installed
TR16 (AiLi) Battery Monitor
Specification from manual
Schaudt EBL 208 S E
Battery charging with mains connection (EHU)
Leisure battery
• Charging curve IUoU
• Final charging voltage 14.3 V
• Charging current 18 A
• Voltage for float charge 13.8 V with automatic switching
Starter battery
• Charging current float charge of starter battery at max. 2 A
Battery charging via the Schaudt LR1218 solar pulse-width modulated regulator
• Maximum charging current 18 A
• Leisure battery and starter battery are charged simultaneously. The leisure battery has priority.
Battery charging while travelling
• Simultaneous charging of the starter battery and the living area battery by the alternator. Batteries connected in parallel via a cut-off relay
Or
Equipment
- 140W solar panel
Recently installed
Schaudt EBL 208 S E
Leisure battery
Starter battery
