UFO
Back in February 2013 we had a problem with the Truma Monocontrol CS 30mbar regulator with no gas coming through. We were in Portugal and stayed with friends pondering what to do. I had the regulator in my hand and was absentmindedly pressing the green reset button there was a psst and the smell of gas. I refitted the regulator and it worked. Conclusion - the auto-cut-off mechanism was stuck. I decided to replace the regulator in October 2015 with a similar Truma one.
On a recent trip the heating was cutting in and out. Cooker rings, etc., all ok. Checked this morning and there is no gas coming out of the regulator. I have pressed the green reset button a number of times. I refitted the original regulator and had gas for a couple of minutes with all appliances working ok and then nothing until the green button in pressed and then the cycle repeats.
With hindsight I should have fitted a filter as Truma recommended, although whether this would have made a difference I don’t know.
We have also had a recurring problem where the heating does not work, but other appliances are ok, when the gas level in the refillable GasIt cylinder is getting low. Fill it up and the heating is ok.
I think the answer is to fit a simple regulator and turn the gas off when travelling.
I need one that will connect to the rigid pipe at the outlet and the flexible hose at the inlet. See photo of where it needs to be fitted. One like this? https://www.gasit.co.uk/30mb-reglator-w20-x-8mm.html They also do a 10mm version, so I will need to check the pipe diameter.
Or if the regulator is fitted to the cylinder I need an adaptor from the flexible hose connector to the rigid pipe.
Any ideas?
Any ideas?
![IMG_20190227_115621[1].jpg IMG_20190227_115621[1].jpg](https://motorhomer.com/data/attachments/9/9475-ac90b4b949f863f3fb77119005cfa06f.jpg?hash=rJC0uUn4Y_)
![IMG_20190227_115641[1].jpg IMG_20190227_115641[1].jpg](https://motorhomer.com/data/attachments/9/9476-a80df4eae2bb1c3a8077945c8c9811e4.jpg?hash=qA306uK7HD)
