TV problem
Bluebelle1
Our tv screen has just half blanked out though we can still see a third functioning normally. I wonder if it is just the result of driving and bouncing around or pressure on the screen as I travel with it face down? It is a Cello Traveller.
It is probably the ribbon inside the TV that connects the screen to the pcb, they are prone to damp this time of the year, it will need pulling apart, or it might put itself right as the weather gets warmer or if the ribbon contacts have corroded then it will probably be cheaper to replace it. Try warming it up with a hair dryer and see if that helps
