I (as many on here and on WildCamping) would recommend Michelin Agilis CrossClimate. You can get a camper version if you wish, but the main thing is to check load ratings.Leo in for service. 3 perished tyres. Gisbournes (haulage company) reccomends Continental camping tyres at £165 each. Advice please for someone with total brain fog at present. Van is plated at 3.4.
Thanks for reading.
Continental is a decent brand, but I advise you not to buy camping tyres. Make sure the load rating is high enough. That's all you need.Leo in for service. 3 perished tyres. Gisbournes (haulage company) reccomends Continental camping tyres at £165 each. Advice please for someone with total brain fog at present. Van is plated at 3.4.
Thanks for reading.
Could you give me the basis fir not having camping tyres please. I have to put this to knowledgeable garage people and want to sound a bit knowledgeable. What liad do I need for a 3.4 plate?Continental is a decent brand, but I advise you not to buy camping tyres. Make sure the load rating is high enough. That's all you need.
Thank you.Camping tyres have thicker sidewalls to cope with being kerbed a lot.
This means they can't dissipate heat as fast.
This means you have to run them at far higher pressure to stop heat building up as you drive along.
This high pressure gives a harsh, noisy ride, poor road grip and uneven wear on the tyres. All your pots and pans rattle. Maybe your teeth too!
Oh, and camping tyres cost more, for no benefit to the buyer.
The actual maximum permissible axle weights are on the plate on the vehicle.
Ideally, you load your van up with everything and all the people and drive to a weighbridge and get the axle weights of each axle to find the correct pressure, but the tyres should be chosen to be able to carry (half) the maximum axle weight.
The 'index rating' codes written in the tyres are numbers like 104/101 which means a max load of 900kg normally, 825kg when fitted in a pair. For single use, you look up the higher number.
My guess is that your van will probably have axle weights of about 1800 and 1600kg which means a tyre load of 900 and 800 respectively, for which a lod index of 104 is enough, but higher is fine.
You don't have to convince the garage. You are the customer. You are paying. It is your choice.
One word of warning: be sure you are sold fresh tyres, not ones that have been in storage for many months or years. Every tyre has a date code as well!
Assuming that the van sits unused outside, worth considering using something to protect the tyres from UV for that time.Thanks all. Did further research and have gone for non camper ones. Yes I know my van does stand perhaps more than some of the intrepid campers on here but given that other than the rare times when I have family on board I don't carry as much weight as people may imagine. There can be a significant difference in price also. The tires being replaced are 09 non campers so I think that helps my decision.
Wish this bloomin brain fog would clear; it makes even simple decision making a marathon!![]()
Yes that's an excellent point. If your tyres get sun shining on them, the UV degrades them.Assuming that the van sits unused outside, worth considering using something to protect the tyres from UV for that time.
That is good adviceLeo in for service. 3 perished tyres. Gisbournes (haulage company) reccomends Continental camping tyres at £165 each. Advice please for someone with total brain fog at present. Van is plated at 3.4.
Thanks for reading.
