marchie
We had the system fitted at the end of September, but only had the opportunity to try it out on the 45 miles return journey from the garage in a pretty much empty Van. Then we parked the Van up until the beginning of December whilst we cracked on with the house renovations
We ran the system at 1.8 Bar on the outward journey (pretty much on the weight limit of 3500Kg), and there was a noticeable reduction in sway when HGVs were overtaking. Driving around roundabouts is much better, with virtually no dive on the front end, but the biggest surprise was today, taking the slip road bend on an Autovia exit with a 30mph limit, I slowed down (not enough!) to keep the line of the bend until the Satnav pinged to warn of being over the speed limit, at a touch under 40mph ... I shall need to keep an eye on the speed, because the M/Home felt so stable and surefooted!
But one of the biggest benefits has been parking up on sloping Aires at Vilafranca del Penedes, Tortosa and Moncofa where the Ramps have previously been deployed at maximum. The ramps have not left the belly locker, and using the air suspension to level both side to side and front to back has been a revelation. One of the better purchases!
Just need now to remove all the 'Just in case' kit that takes up space and payload for the next trip. And look to get the mattress replaced after over 400 nights use in 4 years, and the upholstery foam renewed to remove the feeling of being a dead end kid in all senses of the phrase ...
