Campervanannie
Ok so I dumped my water after my last trip out and today I tried to fill it but because it was cold every time I tried to put the pump on it started to dump again so how do you guys hold the little valve up until you have got the water and heater to a temperature that it stops dumping I know some of you put pegs on but I cannot reach mine to do this, I have however solved it with a fishing hook and a length of fishing line as my little dump valve has a hole in the side of it that I managed to get a fish hook looped through it and now all I have to do is pull the line tight tie it off on a hook on the wall and once it’s up to temperature slacken it off works a treat but it only took me 4 hours to sort it .??
