Water pump electrics
Mash369
Can anyone shed any light on this issue:_
switch on electrics (either leisure battery or Engine battery) all lights etc work as soon as I switch on the water pump the lights go out switch off the pump and all come back on.
Pump works when I connect a battery direct to connections no issues.
Test wiring between pump and switch seems OK
Fuses all checked
I'm bemused, any suggestions would be help#
2004 Swift Suntour/sundance 630G
TA
Chros
Fuses all checked
TA
Chros
Bad connection somewhere in lighting circuit probably at fuse box.
The Pump pulls down the voltage generally and then high enough to overcome resistance in lighting circuit.
Err, got to be a bad (high resistance) connection in the PUMP circuit too. ! If it wasn't then running the pump wouldn't cause a voltage drop issue. Basically it's probably a high resistance connection somewhere that's serving both pump AND lights. Don't just look in the lighting circuit ONLY, it won't be there. It could even be the main battery terminal, or a low/ dead battery even.
