TrevandJenny
I visited our MH today to find leisure batteries flat, zero voltage, after checking out all the possibilities that could cause this. I noticed that the water tank electric blanket switch was on. Hence the zero power.
I measured the batteries voltage, zero, then the SP output at batteries input with batteries isolated, zero.
I can only assume the switch being on drained all power, I wintered the MH late last year and must have knocked the switch situated near fresh water drain.
Will check out voltage in the morning to see if batteries are being charged via the solar panel,
I cannot understand why the solar panel was not showing any current being passed to batteries.
Could it be I have fried something in the charging circuit hence no voltage to batteries.
