Deleted member 144
Walking up our hall way last week bare feet and found the carpet was wet Oh Oh I thought where's that come from, I discovered a radiator was leaking ,it had a pin hole in it , rusty I thought 35 year old that rad, so carpet up, wet through, , turned the rad off and left it for a day or 2 trying to get the inspiration to fix things ,Started Monday , removed the Rad I want the rad in a different place said my wife, of course you do Darling says I, So we striped the Wall paper of the wall, thank the gods for wallpaper steamers great kit, Papered and painted the new paper and the skirting board, Went to B n Q Weds and got a new Rad, 22mm and 15 mm copper tube 3mtrs two new valves £58 the lot B n Q no longer do the Diamond discount Wednesday now ONLY on garden stuff but it was still cheaper than Wicks, I had enough fittings from previous jobs so didn't need to buy those this time. So drain the system, floor boards up cut the old pipe work out , resite the new Rad and re plumb, just finished today , al tested and carpet back down, Second bleed of the Rads and all is well again, I have replaced all but 2 of our Rads now , as when we redecorated other rooms I changed the rads for new modern ones, I have 2 left to do now, neverI hope, as we want to downsize our home and spend some of the dosh, we were going to do that this year after we got back from Spain but the virus put paid to that but hey ho we will get round to it sometime, So that was a job I did not need but it looks good and fresher.
