Im in the corner now for ten mins but need a wee, opps dont matter now sir.Blind git, did you not see the one on its side being stripped of its bricks, what is the point of me going to all this trouble to find decent enough stuff to post if you don't bloody pay attention in class.
I wonder if the residual heat left from the processes are able to be funneled for for more energy elsewhere
That's what I meant in the post above you.I wonder if the residual heat left from the processes are able to be funneled for for more energy elsewhere
It needs to be allowed to cool sufficiently as it goes through the continuous caster mould for a "crust" to form; inside this, the steel is still liquid (and a break-out on the continuous caster, when liquid steel breaks through the solidified skin is highly undesirable - and dangerous - with serious consequences for anyone in the immediate vicinity and for the concaster equipment). The liquid steel needs to solidify prior to rolling, but the outer skin will cool too much. The steel may be placed in soaking pits to try to equalise temperature, but a reheating furnace is often necessary to bring it back up to rolling temperature - this is not an annealing process. Of course in some instances (particularly in the case of special steels), part of a cast may be stored (cold) for rolling at a later date into a product (form, dimensions) that cannot be rolled using the current set-up or for which there are not currently any orders.I couldn't work out why they let it cool instead of carrying on the forming process then do any annealing at the end.
Are you from Bradford then?50 years ago the steel works in Bradford exported the equipment to Korea because it was cheaper to import it
