Thank youI bent a half shaft in Norway, only enough to be a nuisance on full acceleration which I avoided.
On return to UK I had it changed after a short test drive with my trusted mechanic!
After a few miles it became clear that I had changed the wrong one....changed the other one and all was well!
I can only suggest that it may not be too obvious where the problem is!?
PS. A rolling road is often the best diagnosis course....as my mechanic suggested afterwards
ThanksI would recheck the wheels in case you have lost a weight. Seems most likely culprit and easiest cheapest to resolve.
Good luck
K
Thankscheck tyres for bulges and have your tracking done
ThanksCheck steering joints for ware and all nuts are tight .
Thanks there have been a lot of very useful comments which i have written down and will give to the mechanic thanks againThink you should check the tightness of the drive shaft nuts just incase they’ve loosened off a tadd
ThanksSilly question but, did they put the tyres on the right way round, as some modern tyres are directional.
Thankswobble at that low a speed on that diameter a tyre is unlikely to be wheel balance . check that drive shaft end nut is tight !
Hi remove wheels and clean faces between wheel and hub and apply slight coating of greaseHi got 2.3 ducato had front wheel bearing and drive shaft fitted in uk alls well. Arrived in spain steering wheel wobbles between 30 40 mph had 2 front tyres fitted and balanced but problem persists any advice thanks in anticipation
ThanksHi remove wheels and clean faces between wheel and hub and apply slight coating of grease
