merl
Although that's a rule that's commonly touted it's actually not true and there's no science behind it. The only factors that MUST match are battery chemistry and cell count.All batteries then should be of the same output age and condition.
So, don't mix AGM with Gel, flooded etc and don't try and parallel a 12v battery with a 6v battery etc or a knackered battery with a cell short.
The idea behind matching the age/ condition/ capacity/ brand etc is to keep the Ah capacities the same but that actually doesn't matter. Ultimately each battery attains full charge simultaneously and each battery attains discharge simultaneously, therefore the capacity of each battery is realised no matter if their Ah capacities are mismatched or not.
NOW all of the above is correct when connecting batteries in PARALLEL, BUT the batteries MUST match perfectly if you want to connect them in SERIES and this confusion between series and parallel, along with safety bias and information from biased sales literature etc perpetuates the myth.
