Exwindsurfer
Even that’s not original Wully lololLooks good Jeff. You’ve been keeping yourself busy replacing stuff . The only original part left is the key
I’ve been under it since I met Chris TerryWell done Jeff, sometimes it is good to be under pressure
About 2.8 bar.ok all you guys that have air suspension what pressure do you put in ?.
whats that in P S I lololAbout 2.8 bar.
Why so high Bill yours is not a heavy van ?That’s about 40 psi. Mine runs at nearly double that.
I can understand that Wully boarding ferry’s and the the likes.Between 2.5 And 3 depending on load use is to the max when boarding ferries and stuff gives a bit extra lift on the tail end.
I've got AS bags and I put them on to get an extra 300kg rating on the Alko rear axle so need a decent pressure to generate that capacity.ok all you guys that have air suspension what pressure do you put in ?.
