Exwindsurfer
Even that’s not original Wully lololLooks good Jeff. You’ve been keeping yourself busy replacing stuff . The only original part left is the key![]()
I’ve been under it since I met Chris TerryWell done Jeff, sometimes it is good to be under pressure![]()
About 2.8 bar.ok all you guys that have air suspension what pressure do you put in ?.
whats that in P S I lololAbout 2.8 bar.
Why so high Bill yours is not a heavy van ?That’s about 40 psi. Mine runs at nearly double that.
I can understand that Wully boarding ferry’s and the the likes.Between 2.5 And 3 depending on load use is to the max when boarding ferries and stuff gives a bit extra lift on the tail end.
I've got AS bags and I put them on to get an extra 300kg rating on the Alko rear axle so need a decent pressure to generate that capacity.ok all you guys that have air suspension what pressure do you put in ?.
