TrevandJenny
Spring last year I fitted a Victron 75-15 controller bypassing the Sargent unit as advised on here. All working well.
I noticed yesterday that the vehicle battery was only showing 11.7v, strange it normally only goes down to high 12 low 13volts when not used for a while, The leisure batteries were showing at 14v, so solar system must be working, MH last used in November it’s been in storage since nearly three months.
In the past MH has sometimes not been used for around five months and vehicle battery fine after that time, hence solar charging leisure and vehicle batteries ok.
I checked to see if I have left anything on , I did not seem to have. All switches same throughout as usual when left stored.
Could be battery now passed its sell by date! It’s been on charge overnight and showing 14.7v at present but still charging, I have a Ring 8amp charger maintainer., When fully charged I will get it load tested.
Here’s the question, When I changed the solar panel cables from Sargent to Victron did/have I inadvertently stopped the system from charging the vehicle battery via the B2B if that’s the correct terminology. I understood that by changing the charger to Victron it would not alter the charge to vehicle battery.
Any help appreciated.
