Mobilvetta
Been mainly using EHU on my travels but found that the two 110 AGM batteries are lasting less than two days before dropping to 11volts. We have only used the LED lights, the blower for the trauma heating has been on for one hour both morning and night and obviously the water pump and charging two mobile phones, no TV usage or invertors etc. Fridge runs on gas, it seems to me they are failing. I've contacted Alpha batteries as they are less than two years old and come with a three year guarantee, we have two 130 watt solar panels going through a Victron MPPT system, but I noticed that the regulator on that must have closed down this last two days
I have spoken to Leisure tech services at Clitheroe who installed the solar system last year and they think that the regulator has closed down because of a fault with the batteries, they think if I replace them the solar will start working again. I'm useless with electrics, this is why I need to get it checked out if anyone can recommend anywhere from Valladolid and Gibraltar.
I've just drove 3 hours today and the batteries are now showing around 12.98 volts, I've split them and tested them with a multimeter, but as I say even though it is sunny there are no amps or watts going into the batteries. I've attached some readings from the Victron Mppt if anyone can shed some light on it. Thanks David
