rambrose
Got a Renogy clone battery monitor that wouldn't shut up (pulled it out and disconnected for now).
It started when using the microwave.
worked ok previously with 2x 280ah batteries in parallel but had to loan one to my son.
I did change the capacity on the monitor but nothing else.
Looking on the BMS the Fogstar battery showed no issues. About 90-100amp draw.
Continued cooking and used about 10ah.
Currently the battery is partially discharged so can't calibrate.
The manual says completely discharge to set zero. Surely this is not good for the battery.
Battery and shunt is in the garage and I'm under a red blob on the rain radar.
Can you disable the beeping on these?
Any ideas on why it had a fit in the first place?
