Millstone Grit
Our van is back with the vendor for the second time concerning a leaking toilet. If it's used in accordance with the instructions ie. blade in then pull out when finished you get your feet wet. The inside of the cassette housing has to be mopped out when the cassette is emptied. Not good. If the blade is pulled out before use the feet wetting is mostly avoided but not quite but cassette housing still needs mopping. Has anyone else had such problems and how were they rectified. The toilet is a Dometic. Those of you at Littleborough and Anglesey may now be thinking "Aah, that's what that smell was"
