I don't know what wiring you have in place so can't really answer that.Thank you for the advice, could I just add the Cyrix to the existing wiring or would I need to make some changes in the Electrobloc?
The Standard Cyrix is a 120A unit and for that I would ideally install a minimum 16mm cable end to end - you are unlikely to have that as standard. You could try with the existing cable you have and probably will be ok. but just a reminder that you always fuse to the cable capability, not the device, so even if it is a device capable of higher current, you don't increase the fuse size unless you upgrade the cable itself.
Adding another cable is not necessarily that tricky though - today I am in the middle of upgrading my own Split-charge cable from 16mm to 35mm (to support a Cyrix 230A and possible Alternator upgrade). It is involving lying under the van and getting grubby, but all a pretty logical process (just follow the existing cable conduit)
