cheap but easy blackout blinds
mr brown
daughter just used these on her ambo ,very lightweight and easy to cut ,attaches with double sided strip .simple
Grab some pics of the fittings and stuff if you can Nige. Do you think they would work on rooflights? Is there an obvious way to screw it if you need to?
there are no fittings just the sticky strip on one end,and there's a plastic thing which clips on to the pleats to hold it where you want .
it would work on roof lights if it had a track each side for support . if you want to try it i've got a load of white plastic angle to make tracks
I like this. I've often fancied a set of fancy pleated windscreen blinds, but so expensive. Inspired to go DIY.
