Chinese Heater Install - First time use.
GreggBear
After some thought, I have decided to cancel my plans for fitting my log burner & fit one of these instead. Much less mess I reckon, no dust or soot or damp wood stored in the bus, plus the space I was going to use is large enough to fit a diesel heater & still have room for a fridge & more storage. Will be using a separate tank to feed it so as not to disturb the existing setup.
But where can you buy it in small quantities? Local suppliers only deliver large amounts & will not let you collect from the depot.
This is always a problem. I was discussing this topic a year ago with someone at Moffat (sorry, can't recall whom) and they told me that at 'normal' quantities, they were quoted well over £1/litre and even then was hard to get.
28Sec Heating Oil aka Kerosene is actually better than either normal Road Diesel or Red Diesel for the heater - burns cleaner and less choking (it is a common recommendation for anyone running a Diesel Heater on regular fuel to occasional have a stint on Kerosene or Paraffin).
Whereabouts are you based, Gregg?
Reactions: Alf
nabsim
I would love a log burner, if my van wasn’t over 3.5t and me getting closer to 70 I would fit one. However it would be additional to a diesel heater not instead off. Good choice methinks Gregg 👍
GreggBear
I'm just outside Pontefract. Will be looking into supplies shortly as I intend to fit one in my bus now. My old man heats his house with 28sec, which he buys 1300 litres at a time, shall have to see where the drain tap is on his tank.....😈
Reactions: Alf
Get yourself a 20 litre Jerrycan and pump some from your dads tank when you visit. 20L will last a good length of time :)
I use a repurposed oil change pump (https://amzn.to/2TBIfuz) to both pump from big 1000L tank into Jerrycan and then as neccessary from Jerrycan to heater tank. Find it works very well :D
On one of my deliveries of Kerosene, I asked the driver if he could put some into my 20L container (save pumping it out the big tank) and he said he couldn't because of the way it is pumped out, which makes total sense as the outlet nozzle is so large and the speed of the pumping is so fast, so it does make sense that the suppliers will not deliver except to big tanks (and wouldn't be surprised if they were also legally obligated to only deliver into a bunded tank as well).
Users who viewed this discussion (Total:165)
wildebus, Chris356, Lee, bobj808, GreggBear, LANDS43, TeamRienza, nabsim, Northumborman, FERENZA, saxonborg, runnach, Georges, mistericeman, Chrisb1701, TissyD, The laird, Campervanannie, jason9876, Cocky, SquirrellCook, Bigshug, EJB, helen262, Bri, Trotter, Wooie1958, oppy, helmit, mendit, jeffmossy, mr brown, Mr and Mrs Tupcox, Edina, andyjanet, Exwindsurfer, shortcircuit, saxonrosie, wints, Wully, Bouydog, FULL TIMER, trixie88, van Rix, Alf, ton27, paulhelenwilko, Silver sprinter, Ian1950, Obanboy666, Reiverlad, rustydog, xsilvergs, flyby, kevlakes, Mark m, AdriaTwin, Carrerasax, 2cv, Biggarmac, Owlhouse, 2vans, Haaamster, RV2MAX, maingate, Molly 3, Boots, Forresbroons, Chip, tripper, nosfunk, St3v3, Veloman, debs, Mike Woolstencroft, Gixer, Dulvil, yorkslass, royh28, Kennyb, tapfitter, clarkpeacock, Cie, PB2020, gerrevelyn, ibs7491, eurajohn, Hungryhomer, Starkicker, trevskoda, Winks, Monkeybrand, highlandron, Tjay, mark61, Fiona68, Trappers, linkshouse, Dahlia duo, Articstorm, forthpilot, DTDOG, John_o_b, andysm, PeteS, Stevie, Jillyhug, vtwinner, Steveandjulie, RONWOOD, cold, davidjlambert, Grim the Viking, bmc, Dowel, chippythewiz, witzend, JoeH, Hank, CardMaker, Yerbertie, katv, Topmast, WildThingsKev, JimandHazel, StreetSleeper, HurricaneSmith, watchthis, Chris Evans001, Stonedaddy, in h, Clunegapyears, Raymondo, 1977paul, Mark135, alun100, walpeter, Yorkscol, gilly3001, DaveAdele, Beltman, Edward B, robmars68, Boatman7973, neckender, rivabill, Bobtaylor, daygoboy, Mini tony, McNasty, THE COLLIES, Forcesixwindy, Pudsey Bear, PatB, David0412, bjh, old cronies, Frogman, Kenno, Dr Who, davef, traveller221, cornish hymer, ian reed, Kimbowbill,
