mistericeman
Is it worth sticking a clamp on meter on and seeing how much current is actually being drawn?
You would hope so, but manufacturers almost to a man try to get away with the cheapest possible components for every single part of the vehicle end to end. And BMW are no better than anyone else in this regards despite their prices.Having thought about this a bit more I’m not sure I’d go down the proposed route. As Dave said change plug and socket and check fuse isn’t loose. If possible try in a socket in a completely separate circuit To narrow down the possible sources of the problem.
Since ev’s are supplied with a cable with a 13 amp plug and a 10 amp fuse the manufacturer expects them to work without overheating. There’s either something wrong with the plug, the socket, the circuit, the supplied lead or a combination of several issues. If you change to a non-standard set up you may not have any claim if something seriously bad happens. You should probably incorporate a 10amp fuse in any new set up.
(just my thoughts)
I charge my EV overnight at 4.5p (fixed until May 2024)!!!When we bought the leaf 4 years ago there was a scheme by which we got a dedicated 7kw Type 2 tethered charging unit for free Fitted by Chargemaster. It works fine, although we tend to use the 13amp plug when the sun is shining as then the pv panels on the house will supply most of the electricity.
I was looking at the faqs from Chargemaster ”how much will it cost to charge my car?”. When they published in 2017 they said leccy cost around 11p a unit….if only!!
Earthing spikes enable rcd trips, should be a negative earth link from what I read on the tinternet.If I had a suitable meter I would do so, however I don't, but now I have fitted the new socket and plug everything is running ice cold .
In the end, I fitted a 32 amp socket and plug from MK, however the entire shooting match is protected by a 10amp trip switch on the individual circuit from the circuit board, I also fitted a 1 mtr. earthing spike connected to the socket with a 5mm multi strand cable and the socket also has the standard house ring main earth as well.
Phil
Something you might want to consider (maybe St3v3 could comment, agree, disagree, etc) as this line is feeding an outside socket, is rather than a standard MCB in the Consumer unit, use an RCBO, which will give you a dedicated RCD function as well, plus a dual pole protection to the socket.
Just a thought.
what's a "granny charger"?I am a bit surprised anyone would use a granny charger regularly, mines been use perhaps twice if that!
The problem apart from the risk of overheating especially when using worn mains sockets is efficiency.
The obc in the car has to convert 230v AC into typically 400v DC.
There is an overhead when doing that proportional to the rating of the supply being used That overhead is money down the drain.
Charging my Kia Soul via my granny charger is only 67% efficient, using 16A evse increases that to around 77% and a 32A evse gets it up into the low 90s iirc.
It is well worth using some of the popular apps to check the obc efficiency, for my Soul pids were available to allow info to be viewed using Torque pro.
So yes although ev charge points are stupidly expensive for a box that only needs to contains a couple of contactors and some resistors to tell the obc what the available current is they are more efficient in use and would pay for themselves in a few decades
Fortunately mine was £80 from eBay!
What the fook is the AFDDs.Absolutely should be an RCD somewhere in the feed to it.
The MCB may be fed as is from an RCD, which is electrically ok.
As always, you really want sparky to look it over and suggest options...
RCBO's on all circuits is best. Regs have changed again, AFDD's are now required on final ring circuits.
OBD-II PIDs (On-board diagnostics Parameter IDs)Well, the main thing I have learnt from this thread is that people with electric cars LOVE acronyms.....
Granny Chargers, OBC, Zappi, evse, pids, ....
All double-dutch for anyone who doesn't have an e-car.
