Mr and Mrs Tupcox
I have 4 x 100amp Relion lithium and run a renogy 2000watt inverter no probs.But if I was starting again I would be putting 2 x 300amp lithium in place only because I don't like the idea of only one battery but that's just me if the battery has a fault your goosed till its sorted where as I can just take the faulty battery out .
Maybe connects to the cerbo unit(?) if that's the right name
What’s that Neil lololMaybe connects to the cerbo unit(?) if that's the right name
As said they lost me...Maybe connects to the cerbo unit(?) if that's the right name
I've nowt as posh as that Neil lololMaybe connects to the cerbo unit(?) if that's the right name
I just rely on Phil to keep me right when it come to electrics.As said they lost me...
that is spot on. you can connect it via either the VE.Bus or VE.CAN (think VE.Bus) to a Victron Venus OS unit like a Cerbo GX and see the battery info directly an not have to get a Smartshunt or BMV monitor.Maybe connects to the cerbo unit(?) if that's the right name
Yes your right I tried it lololGood charger but fan is noisy.
The differences are:
