Exwindsurfer
Phil amazon have lucas fuel addtive for £35.60
Tried many and found no noticeable improvement, they say seafoam is good on utube, Scotty Kilmore.Might be worth a try Trev lol
Trev I don’t think this is correct, can you link the lab tests please? It isn’t an octane booster as some of the other products mentioned here are it’s for keeping everything cleanRedex was lab-tested many years back and found to do nothing except empty your pocket, I found by accident that cellulose thinners cleans carbon of heating boiler swish plate and nozzel/jet very well, so now and again i put a pint in my central heating sys, not required cleaning in 5 years, just wonder would it do the same in the diesel engine injectors.
I have seen a few motorcycle engines stripped down after Redex was added on a regular basis. They were as clean as a whistle. I believe it is a good thing for engines and as an upper cylinder lubricant it is effective.Trev I don’t think this is correct, can you link the lab tests please? It isn’t an octane booster as some of the other products mentioned here are it’s for keeping everything clean
Yes a light right foot.I just drive with as light a right foot as possible and rely on opening the throttle just ahead of the climbs to boost the rpm on a thoroughly warm engine to remove the soot. Averaged 29.34mpg [Tank to Tank measure] over 9684 miles since April 2021
That’s what I use it for, keep everything as clean as possibleI have seen a few motorcycle engines stripped down after Redex was added on a regular basis. They were as clean as a whistle. I believe it is a good thing for engines and as an upper cylinder lubricant it is effective.
Opening lines from a Round Table After Dinner Speech:That’s what I use it for, keep everything as clean as possible
Cheeky so and so, Graham. I was Speaker's Secretary at Bitterne & Woolston Round Table 1013, so heard a variety of ice breaker introductions, most of them extremely rude, all of them non PC. The best, and just picture the image it conjures up. was from a Senior Official in the Paralympics set up, who said that people are amazed to hear that the visually impaired are able to Sky Dive. 'Of course. people invariably follow up with the question, 'How does the visually impaired person know when they need to prepare for landing?'....and did they say you/they couldn't be funny either Steve?
I know what it is, and no link as i looked this up donkeys ears ago, test sid money wasted, as many wonder solutions say, there is a cleaning solution already in the fuel.Trev I don’t think this is correct, can you link the lab tests please? It isn’t an octane booster as some of the other products mentioned here are it’s for keeping everything clean
I don't think I need put any in ours (Peugeot Boxer 2.2 2Berth) just arrived at Cheshire Oaks Cruise Control set at 55mph Motorway was getting 36mph average.I just drive with as light a right foot as possible and rely on opening the throttle just ahead of the climbs to boost the rpm on a thoroughly warm engine to remove the soot. Averaged 29.34mpg [Tank to Tank measure] over 9684 miles since April 2021
Looked at most of the tests about fuel engine cleaners, what i found is that most are snake oil and do nothing in lab tests, one that did seem to work is called sea foam in the USA, hydra maximus is at the bottom of any lists.View attachment 65013
My Iveco is a 2.3 Daily bus 3.5 ton body, originally a disabled school bus but I have removed the wheelchair lift that was very heavy! Thinking about getting re-mapped but for Torque not BHP as this is apparently the better way to go?That is an incredible difference in mpg !.
Please give a recent figure assuming you are still using it. Also how heavy is your camper please
It’s the best way to goMy Iveco is a 2.3 Daily bus 3.5 ton body, originally a disabled school bus but I have removed the wheelchair lift that was very heavy! Thinking about getting re-mapped but for Torque not BHP as this is apparently the better way to go?
Put your Reg number in on Celtic tunning and see what you get from standardIt’s the best way to go
