Exwindsurfer
That tank better not leak after all this workThe tank may look the same as when i started but its had two coats of zinc primer + three coats of white stone chip and then a coat ofred tiwn pack so it can beseen as a gas bottleView attachment 64252View attachment 64253
FFS Terry lolololThat tank better not leak after all this work
PmslTank envy enough to bust...
K
Looks like an enormous vibrator ... And with the protective shield, it could be marketed as the Armor DildoHad a visit from bomb disposal yet? Looks a bit like a cruise missile!!!
But why,t hought you wanted white? I have seen cylinders from manufacturers in just about every colour including whiteThe tank may look the same as when i started but its had two coats of zinc primer + three coats of white stone chip and then a coat ofred tiwn pack so it can beseen as a gas bottleView attachment 64252View attachment 64253
Red is for danger NeilBut why,t hought you wanted white? I have seen cylinders from manufacturers in just about every colour including white
You painting your van red, Jeff?Red is for danger Neil
The 2 pack should be over the 2 pack zink, then the stone chip, hope you had it blasted first to give the zink a key and remove any blue scale.The tank may look the same as when i started but its had two coats of zinc primer + three coats of white stone chip and then a coat ofred tiwn pack so it can beseen as a gas bottleView attachment 64252View attachment 64253
I wish Nabs lolooolMight of known you would be first with hydrogen power Geoff lol
I am getting mate to sand blast it Terry and see what it looks like.I wonder how it would fare with a sand blast, Jeff. Would you need a complete replacement?
Certainly be interesting to see how it pans out, that said, tank me look reasonable for age, formal tests would be required, see link https://bcga.co.uk/topics/cylinder-testing/I am getting mate to sand blast it Terry and see what it looks like.
