Pudsey Bear;n16886 said:Do you not have a shower? 20-25ltrs won't last long at all, also means if you want to wild camp, you're going to need to find water more often.
What do you mean by strapped on the carrier, that sounds like you mean on the back of the van to me, if so you need to have a black plastic container or you will get algae problem very quickly, it will also freeze rapidly as the plastic tends to be quite thin.
Just sent you a PM wildebus
Hi. Carrier means under-chassis spare wheel carrier (see picture in first post). This is for grey water, not fresh, as well. I will be using internally stored 25L Water carriers for fresh (probably a pair) as I find these nice and easy to take out to refill.
shower wise ... will have a shower/WC enclosure probably, but showering means a fair amount of HOT water, so in practice will be used very intermittently (if at all) and without permanent water plumbing (except waste)
