Do they all have the selector Phil? Charlie has a 75/10 I think it is and I didn’t see anything on it, just the jumper next to the terminals. Didn’t look that hard though as default was right setting for the tiny 72Ah lead acid battery that comes with those vans.Either with the selector on the bottom or a Bluetooth dongle.
a lot of batteries on sale including a certain over hyped brand pushed by certain YouTubers
The Jumper position selects the Algorithm for the LOAD Output only (that is why you don't see the jumper on the the controllers without a LOAD terminal such as the 100/30).Do they all have the selector Phil? Charlie has a 75/10 I think it is and I didn’t see anything on it, just the jumper next to the terminals. Didn’t look that hard though as default was right setting for the tiny 72Ah lead acid battery that comes with those vans.
It is not obvious at all. How would people know Victron use "Blue" to mean nothing specific and "Smart" to mean Bluetooth (e.g. BlueSolar vs SmartSolar and Blue Power vs BlueSmart)That’s right David I couldn’t remember what it said the jumpers were for so I just said jumpers. I have a dongle on my BMV700 so can temporarily use that if Charlie decides to fit his solar. Think he is going for a Bluetooth controller instead at some point though. He didn’t realise the Blue Solar wasn’t Bluetooth lol
I would guess Ecotree but happy to be corrected.Which brand do you refer too?
I bought 120Ah KS Energy in Jul 21. The BMS is a PITA, causing the battery to go comatose when the SOC is around 95%, so when the fridge or the Trumsa calls for a teaspoonful of electricity after about 2 hours in the evening, the battery cannot respond quickly enough, and the 12v system trips for about 1 second. This throws a Truma error code, losing the menu settings and also loses the multimedia stereo settings, so reprogramming is a regular and frustrating exerciseI would guess Ecotree but happy to be corrected.
I'm looking at Roamer and KS Energy at the moment. Anyone got experience of those?
That is true to a fair degree, but should be mindful that to configure the non-bluetooth versions of the solar controllers and BMV monitors, you still have to use VE.Connect through the Victron VRM as well as the Cerbo. Having them connected to the Cerbo alone is not enough, you must have Internet access to the Victron site.One thing I have noticed is that if you are going to connect via a cerbo, is that there is not a lot of point spending the extra on smart solar as the cerbo takes over the control of them instead of using the smart network.
It is a shame the seller as about as responsive as the battery is!I bought 120Ah KS Energy in Jul 21. The BMS is a PITA, causing the battery to go comatose when the SOC is around 95%, so when the fridge or the Trumsa calls for a teaspoonful of electricity after about 2 hours in the evening, the battery cannot respond quickly enough, and the 12v system trips for about 1 second. This throws a Truma error code, losing the menu settings and also loses the multimedia stereo settings, so reprogramming is a regular and frustrating exercise
I emailed Neal at KS Energy but he never bothered to reply, so, when I have the spare cash, I'll buy a competitor brand that has the BT based BMS removed or disabled to avoid the 12v drop problem. David of Wildebus fame wrote about the problem with the BMS and the solution which can be mitigated by sitting in the van in mid June with every light blazing away, trying to keep the batter6 working, instead of dozing off. Neighbouring M/homers think we're mad ...
Thanks, David. Your reply fleshes out my sketchy 'technical' description!It is a shame the seller as about as responsive as the battery is!
I fitted a pair of 100AH Lithiums from DC Tech a couple of weeks ago which used the Daly BMS. That seems to go into a standby mode but wakes up (and then stays awake) at the slightest provocation, which seems a reasonable enough way to do it.
The Poweroad Subzeros would not go into standby until no load or charge for a full 24 hours, so again in a Motorhome setup, would work out ok.
And finally the batteries I like most right now - the Xplorer PolarMax's from Alpha have the Standby option disabled from the start so it is always available (the App says Standby when it is not charging or discharging, but is remains awake). even though they don't go to sleep, the power drop when not used is so low it doesn't record.
Get your money back on it Steve it’s under warranty and obviously not fit for purpose. My cheapo TN Power have never missed a beat in over two and a half years but they are dumb (no Bluetooth or heating)I bought 120Ah KS Energy in Jul 21. The BMS is a PITA, causing the battery to go comatose when the SOC is around 95%, so when the fridge or the Trumsa calls for a teaspoonful of electricity after about 2 hours in the evening, the battery cannot respond quickly enough, and the 12v system trips for about 1 second. This throws a Truma error code, losing the menu settings and also loses the multimedia stereo settings, so reprogramming is a regular and frustrating exercise
I have just put a Roamer 460ah in my motorhome and boy what a game changer, air fryer, microwave, hot water, hair drier. don't even touch the power, I had to wait a couple of months for delivery but well worth the waitI would guess Ecotree but happy to be corrected.
Ecotree.Which brand do you refer too?
That’s a decent amount of capacity, if it’s a single battery it must be huge?I have just put a Roamer 460ah in my motorhome and boy what a game changer, air fryer, microwave, hot water, hair drier. don't even touch the power, I had to wait a couple of months for delivery but well worth the wait
I’m thinking about buying 16 280ah lithium cells for use at home. The house points the wrong way, but I can get a 1000 watts on the front and a bit more solar on the back. I should almost be able to come off grid.
Where in UK are you, I could do with a new roof, and have Solar.seriously thinking of covering my roof in Panels the whole front roof faces perfect south. I could fit them myself no bother as we take them off and re fit when doing some new roofs it’s the final connection to the meter I couldn’t do. I would love to go down th route of fitting a big battery bank keep us updated on how you plan yours. Think I could get about 30 40 panels up there.View attachment 64214
