Carrerasax
Whoops!! Ta
Carrerasax;n33192 said:Is this one any good! can any techie out there give any advice/suggestion.
TP-Link 300 Mbps 3G/4G Wi-Fi Router, 1 UBS 2.0 Port, WPS Button, No Configuration Required, UK Plug (Archer MR3420) https://www.amazon.co.uk/dp/B003WK62..._toC3Ab8N2QBFX
Minisorella;n33829 said:I seem to remember looking at WorldSIM data prices fairly recently and discovering that their data is very expensive. The Huawei and aerial prices are fine but see if you can find out from their website what they charge per Gb of data and how long it lasts. I can't seem to find it this time!
All those words and what they meant was **** you, thanks for the updatenabsim;n34203 said:Regarding to your query, We have checked you consumed data with your 10 pounds on 05/05/2018 you consumed 64 MB two times and 21.512 one time and you were charged for this 10 pounds. You can check it by yourself. Kindly login into your account. If you have any problem kindly contact us back.
nabsim;n34203 said:Well its okay to buy the Huawei from them but forget Data. Was in a black hole in Anglesey this weekend and found one spot half way along a cliff walk where I got enough signal on my 3 phone to open web page, couldn't really see what I was getting but put £10 credit on the roaming SIM they sent me. Turns out a tenner gets you around 120Mb data, what a rip off. It only gave me enough access to log on the worldsim web site, won't be doing that again
Here is the response to my query on why I couldn't connect after spending my tenner:
This is what I do and up to now have not had a problem DH and I can both be on internet at the same time, so for us is brilliant. Works very well all over FranceProbably teaching my grandpa/ma to suck eggs with this reply but I figured other people may read your topic who don't know anything about mi-fi or what's available
A mi-fi unit works on exactly the same principle as mobile phone data, ie connecting to the internet via a sim card. The main difference was that a mi-fi device connects itself to the internet and then puts out a wi-fi signal, so you can connect a phone, laptop, tablet, etc, all at once, usually up to 5 devices. These days though, most phones will allow you to set them up as a 'hotspot', so that you can share the connection in the same way. Personally, I've found that my mi-fi unit usually gives me a better internet connection than my phone but it's possible that could be about the mobile provider rather than the device I guess. You can buy mi-fi devices that have an aerial socket... stick the aerial outside the skylight for an even better signal. When all's said and done, it's still a sim connection but if your phone is 3G and a mi-fi is 4G, then you'll gain speed using the mi-fi's wireless signal.
The big drawback with using your phone as a wi-fi hotspot is that you're stuck with your own phone sim and whatever data allowance you get through your provider. If you can't get a signal somewhere on your phone, then that's it, no signal. With a mi-fi unit, provided you have an unlocked one, you can switch to a spare PAYG data sim from any other mobile company... and could even buy a local one abroad if that looked like a better bargain. Personally, I don't think it's worth getting a data sim on contract, a) because you're stuck with one company again and b) because you can pay around £2 per GB for PAYG data and that's far cheaper than with most contract data sims, plus you don't have to lose any data if you don't use it within a month. For example, Trio sims from 3 are really good value and have good coverage in the UK and Europe. The 12GB one is valid for up to a year (depending how quickly you use the 12GB) and the 24GB one is valid for up to 2 years. They're currently £28 and £45 respectively... see links below.
https://www.mymemory.co.uk/3-payg-4g...12gb-data.html
https://www.amazon.co.uk/Three-Mobil...+trio+sim+24gb
