Campervanannie
I was going to the Oxford Wild Festival but then this happened but today I had an idea so I’m going back to basics going in the Doblo with camping gear 2 day festival it will be fun ??
tears rolling down my cheeks..........good on yer girl......no stopping you eh.......go for it.I was going to the Oxford Wild Festival but then this happened but today I had an idea so I’m going back to basics going in the Doblo with camping gear 2 day festival it will be fun ??
Now for the good news I think it seems it might be the oil pump that has gone just waiting recovery to the garage now.
Can't see how the oil pump failing would cause smoke from exhaust.
I'd be much happier with a failed turbo than a failed oil pump, the likely damage from a failed oil pump will be considerably more serious than a turbo failure.
As soon as the oil light came on I pulled straight onto the hard shoulder and turned off the engine so it was seconds so hopefully not too much damage done??Let's hope it's not too expensive whatever the problem is.
As others have said if you turned off as soon as the oil light that would minimise damage.
It sounds as if you've avoided the big danger with turbos which is when oil seals pack up and the oil goes into engine and acts as fuel causing catastrophic runaway.
Turning ignition off does nothing and unless you can stall the engine within seconds it's toast.
If the turbo has broken then as others have said the intake system will have to removed and cleaned to ensure there's no debris waiting to get ingested - the same for oil system where sump removal to check for debris would be prudent.
The sevel engines have very easy access to the turbo on the back of the engine.
Anyway I hope it's not too serious and you are soon back on the road again.
That's something I've not heard of, can you supply a link to the information as I'm very interested.I'm told most modern diesels have a butterfly valve that closes when the ignition is switched off.( I Cant remember what it is called though) This restricts the air flow to the engine to stop normal diesel engine run on ( dieseling ) when the ignition is turned off. If a turbo oil seal fails this butterfly will prevent engine "run away" if the ignition is turned off by starving the engine of air. I think this is part of an EGR valve.
