sydnsue
I am about to change my solar controller from a single battery type to a Truma SDC10 that also charges the vehicle battery. Reconnecting the leisure battery is easy but the new connection to the vehicle battery is not so obvious. The controller has plus and minus output for the vehicle battery. Do I run just one positive wire to the battery terminal? What happens with the negative connection? Can I just connect it to a local earth or must it also go to the battery negative terminal?
