RAW
Good Points | Bad Points |
Having looked through receipts from the Garage here is detail of professional mechanical work done last year which totals IRO £1500 last year (2019)
- Engine water Pump Replaced with New Bugatti water pump
- New Spark Plugs
- New Oil Filter
- New Air Filter
- New Petrol Filter
- New CV Boots
- New Rear Brake Cylinders
- New Rear Brake Pipes
- Clean Carburettor and Tune Engine, Engine Timing
- New HT Leads
- Tracking
- 2 NEW Front Tyres 185 14C
- New High Capacity Solar Panel 285W fitted to roof bars and cabled
- Solar Controller and additional Leisure Battery fitted
This is switch isolated front to rear as batteries are differing capacity - All Herzim strip external replaced with new
- Rear rooflight above toilet, removed, cleaned and resealed
- Isolated USB Charge Point and Voltage Meters placed in Dash
- All plumbing sorted out
- Split Charge Relay, voltage sensing, introduced and Leisure batteries charge by Alternator
- Roof coated in Crompapol for additional protection against elements.
Vehicle is roadworthy with Valid MOT and Taxed / Insured so can be test driven
There are MANY MORE PICTURES AT (click below)
ra-w.uk/SYLVIA
Vehicle is located in Hebden Bridge, West Yorkshire (above any flood areas !)
