RoaminRog
We have a local garage, that has stayed open during the pandemic because it has the contract to MOT ambulances etc. I phoned them up to see if they would MOT Mimi, our Motorhome.
They agreed to test her last Monday at noon. I had some other things to do on Monday, so I took her in about 10am and parked her in a parking spot reserved for MOT.
At noon, the tester drove her into the MOT bay, but as she was going in, the gear selection indicator on the dashboard was going from first to sixth gear randomly. The tester was alarmed, and switched the engine off. They called me, to see if there was a knack in starting her, and I went straight over there to try to start her.
Mimi has a Quickshift gearbox, and I could select every gear except neutral, but couldn’t start the engine.
So there she was, blocking the MOT bay, stuck, I was not flavour of the month.
So far, I have had two people with diagnostic readers, trying to help. One of them, eventually, managed to start the engine in reverse gear, and they were able to back her out into the yard, where she still is now.
The other chap, managed to get her into Neutral, and I have tried many times to turn her over, but when I turn the key absolutely nothing happens. No clicking from a loose battery terminal, no whirring from a dodgy starter motor, no headlight dimming, just silence, apart from my language of course.
She is going for a ride, on the back of a lorry, in the next couple of days, to the chap who fixed her last time this happened, and fingers crossed he can work his magic again. I am also going to suggest the ignition switch, which may be at fault, but that wouldn’t explain the gears jumping up and down. Large black cloud forming over the Roamin household!
