Trumatic E2400
forthpilot
I have a n E2400 pre 2001 as my cab heater, and someone has decided that their need of the cowl cover is greater than mine. I have drawn a blank on sourcing a replacement. Truma say the part is obsolete, and all the usual sources say they have no stock. Can anyone tell me if the post 2001 cover KKW-2 can be modified to fit.
I realise that the cover is not essential, but it is easier just to remove the cover when the heater is needed, than to access the heater and remove flies , spiders etc. from the combustion chamber if a fault occurs.
forthpilot
Yes that is the post 2001 cover, but I don't know if the diameter is the same, and I would have to modify the locating lugs, as the later cowl is a different design.
Thank you for replying.
Stewart.
2cv
Moderator
Stewart.
It does say it’s for pre 2001.
