oldish hippy;n4877 said:just cut the photo in half and upload two halfs
Admin;n4883 said:I have changed the max res to 6000 x 4000 pixels. I need to be careful with disc space in the future. Server class SSD storage is not cheap.
Full Member;n4462 said:It's all about how the image is processed after being taken, Annie.
The photo image starts as a 'matrix' of coloured dots called pixels. If the image is say 1500 pixels wide by 1000 pixels high then the total number of pixels in the image will be 1500x1000=1500000 or 15 million pixels, That's quite a lot of information for your camera to store, especially as each pixel has to be recorded in terms of it's colour and brightness etc.
Before the image is stored the image information is processed to reduce it's size by a piece of in-built software called an algorithm. Many types of algorithms have been developed to do this work but currently the most popular is the 'jpeg' algorithm.
The algorithm scans the original image and should there be little or no difference between several pixels it notes this fact and simply stores something like "put 5000 pale blue pixels in the top right hand corner of Colin's Canary Island photo". This is also done for say the beige rock on the volcano side. This sort of thing is very rapidly done for the whole picture so that the image size as stored is much reduced.
When the camera 'reads' the file information it effectively does all this in reverse and - hey presto! - the original image is very closely reproduce for all to wonder at.
Now the effect of this on uploading to the site. You (and the vast majority of us) will leave the camera settings as they are even if they are adjustable. You might imagine then that all images would be the same file size and so if one photo uploads then they all should. If we consider how those files were created their size will depend not only on the camera setting but also on just how much duplication of pixel type there is in the image. The more duplication, the smaller the file size. Hence some of our images are above the limit set by Phil or the server owner and some are below the limit (currently about 890Kb).
I hope all this makes sense and is based on my rather limited knowledge in this area.
Incidentally similar things are done with music where the original music is 'sampled' and the file size reduced. The software most commonly used here is the 'mp3' algorithm - which would have been used on the music you listen to.
As always, I'd appreciate input from the experts!
Colin ???
Rockburner;n4961 said:Actually - that's a pretty good explanation in simple human terms for a pretty complex bit of software. Well done.![]()
2cv;n4991 said:I got a little app, free or 99p to be without a small watermark. Makes it very easy on an i pad to resize. See https://motorhomer.com/forum/community-forums/off-topic-lounge/3614-test-thread
alwaysared;n5092 said:I use FastStone Image Viewer for Windows, there is a install or Portable Version available free for home use. It also renames files and you can create slide shows etc.
Regards,
Del
Full Member;n5176 said:Thanks for the information, Del. I'll have a look at your suggestion once I'm back in the UK
Colin ???
Campervanannie;n5237 said:Take plenty of photos to post for us. ?
Edina;n5274 said:I keep a folder on Postimage of photos etc I want to upload, then just attach to my post via URL link and I don't get any size problems.
2cv;n5277 said:Only problem with that is that if they go the way of photobucket all your online photo posts become blank.
One way forward is for Phil to increase the acceptable upload file size or include some software that reduces the size of the file just before or after it is uploaded, though there may well be better ways.
Colin ???
