Exwindsurfer
That 40mm fillet ended up 62mm lololI onlyneed to put a 40mm filler and it's back together
I carry a 40ltr water barrel Gordon so not a problemWill you need a bigger water tank jeff
Gordon, he will need his derrière calibrated to have a clean drop into that small hole, unless he uses a funnel?Will you need a bigger water tank jeff
PITA Rog, one way for the shower, total opposite for the kitchen sink, thanks Swift for the joined up thinking.I know it’s too late now Jeff but will you have to park in a certain way, in order for the water to drain away?
Many motorhome shower trays have two drains on different sides of the tray.
It's a truma gas and electric water heater Andy 10ltrs it will be more than enough.What heating do you have for hot water ? Are you using your solar/ electric to heat water
The other picture are a bit blurred. You can see how much I've moved the front wall so the shower tray fits going to have to try and get some fablon to hide the bare wood.I’ve desided to put a shower in the toilet compartment I am using a house hold shower tray 1000 mm x 700mm as you can see it’s a lot of work and should have done it years ago because of the width of the tray I have had to move the front wall a further 40mm out luckily my wood floor is 70mm above the steel floor of the van so not a prob getting the wast in place .View attachment 71641View attachment 71642View attachment 71643
Is that sketcher shoes you havebonWell that the channel and hole cut for the shower wast pipe just wait five r the shower trap the turn up.View attachment 71680
No slippers lololIs that sketcher shoes you havebon
Oh! I have. Sod it.For a thick BS, you are a clever sod. Although I'd never say it in public, that van is a credit to you
you taking firearms across borders Gordon or waiting for him to cross to you?Cannae wait to get a shot o it
