Topmast
My van has been parked up for about ten days admittedly in pretty high temperatures but walking past it today one of the rear tyres was flat when I put the compressor on I found the valve stem had split to the extent I was unable to get any air into the tyre, as both tyres were replaced last year and both valves renewed at the same time I can see no reason for this . Is it possible that the heat was so great that it increased the pressure enough to burst the valve? Admittedly I left the wheel brace beside the van in the sun and burnt my hand quite badly when I went to replace the wheel.Todays temperature was around 100 degrees.
