mikewroe
After much discussion I have bought an Alpicool CR90X, collecting it today. This is to replace our old 3 way fridge.
From memory I believe the max current draw is 6 amps. I require about 3m of cable to run from the LB to the fridge, please could someone advise to best size cable to use.
Already wired is the existing 12v supply to the old 3 way, albeit only powered when the engine is running. As this is relay switched, is there any reason why I can piggy back onto this. This way I have the benefit of a poor mans B2B system?
