We found with the display showing so many errors in it's calculations (as what's seemed to been experienced here), we dropped the NASA panels and have stuck with Victron ever since, for many reasons like battery types, Peukert's law etc. What is also great about Victron is the ability to process battery banks by using Midpoint voltage monitoring (BMV-702/712 only)
to save grief, I've copied and pasted the blurb;
"This feature, which is often used in industry to monitor large and expensive battery banks, is now for the first time made available at a low cost, to monitor any battery bank.
A battery bank consists of a string of series connected cells. The midpoint voltage is the voltage halfway along the string. Ideally, the midpoint voltage would be exactly half of the total voltage. In practice, however, deviations will be seen, that depend on many factors such as a different state of charge for new batteries or cells, different temperatures, internal leakage currents, capacities and much more.
Large or increasing deviation of the midpoint voltage, points to improper battery care or a failed battery or cell. Corrective action following a midpoint voltage alarm can prevent severe damage to an expensive battery."
The Victron will give you a more accurate read-out of the state of batteries and help care for them better as explained above.
Battery ratings...………. well that's a whole different argument and will go on till the cows come home!!
Everything that needs to be explained has been explained beautifully, so no need to add to it. On a personal level, I have always worked on 45% SOC of the rating of a lead acid battery as a safety buffer (till I started using lithium). I know a lot of manufacturer claims well exceed this percentage, but by having a safe figure to work with, you know in your own mind that you won't take the battery to a level where repeated discharge doesn't put it down to the path of no return.
Going back to some the OP's original posts and issues surrounding the B2B draining power, who's was it that you had fitted?
Personally I much prefer the use of B2B technology, especially with connecting your battery bank and the battery ratings higher than that of the engine battery they are connecting it to. Having a good make of B2B is like having a good 3-4 stage charger powered by the engine, so for long term battery heath (and the fact that most B2B's now have Li profiles, so future-proofing your install), but has been proven to charge your batteries 5-20 times faster. I've loved having one fitted, as I tend not to relay on solar during the colder months, where we hit the batteries harder than that of the summer months and want a speedy recovery after a few hours driving.
