Longer, heavier Moho implications?
Phantom
We're planning to change our motorhome in August, we don't want to at all but the sole reason is that we choose to carry a heavier scooter in the garage that puts our current MH very near it's rear axle limits even without any water etc onboard, but are not interested in any other carrying methods. Things had been just fine until we visited a weighbridge :oops:. We Currently have a 3.5T MH and uprating to 3850 kgs would not really help too much.
Our current Mercedes sprinter based MH is 7.3 metre long & about 3 metre or so high. I gather that road tax will be about £100 cheaper for say a 4.6T as PHG, but would also be interested to know of any other implications if we say went around Europe regarding tolls and ferries etc? They always say that you will find that your first MH is not quite 100% ideal as first thought, but this was very close and we intend to just buy the same layout but on a heavier chassis! Are there any real pro's and con's of being under or over 7 metres long and height ?
Don’t know how much more capacity you need but if the layout and everything else is what you want you can go above 3850kgs. Our Phantom is total 4t, 2430kgs rear axle and 1750kgs front.
I have just had my 3500kg replated to 4100kg, practically a paperwork exercise as I’ve got air suspenders on the rear already. Is that an option for you to retain the MH you know and love?
When you go heavier its usually with a increase in size(length) so you dont gain all the increase with gvw as payload , also with increased length quite often there is a increase in the lever arm of the garage load . So you need to be careful that you don't take one forward and two back .
I agree with that. Ive been looking for a new van for years to replace our Kontiki 640 and a heavier van is not always the solution. The newer Kontikis for example some are 4.5t whereas our current one is 3.5t but has more "available" payload than the heavier model. God knows what they stuffed in it to make it so lardy. I started to think the best option would be to find a van thats say 3.5 tone or 3.85t that is able to be uprated to 4, 4.25 or even 4.5t thus giving it a much higher payload but I just lost the will to live trying to figure it all out and then find a model that suits our preferred layout (rear lounge, front dinette). I gave up, several times. Still got the same van. :D
An extra consideration is the number of axles, many tolls, ferries etc. both in the UK and the EU charge by the number of axles, so with a tag axle you are charged the next higher category.
A cheaper and easier solution could be a side loading trailer. You won’t need to change your van with the associated monetary loss, but you may need to get a towbar fitted.
Also, it will give you 3 axles, so French toll charges might be higher.
The first time we weighed it it was 2470 kgs on the back axle and a total of 3830 kgs with the scoot and 80L of water, though have lost and moved some weight since to get the back axle and tyres about down to about their 2240 kgs weight limit without any water or the spare wheel onboard. I didn't think that I could get the back axle uprated by another 200 kgs so that might work out, but I do already have air assisted suspension.
Quite possibly?
When you go heavier its usually with a increase in size(length) so you don't gain all the increase with gvw as payload , also with increased length quite often there is a increase in the lever arm of the garage load . So you need to be careful that you don't take one forward and two back .
Well that's the main problem with having 2 metres overhang with the garage, the leverage effect of adding up to 50% more load than the actual weight to the back axle. It seems that the 4.6t chassis is about the same dimensions but the twin rear wheels will take more load. The thing is that the more weight at the back, the more you take off the front. When my current set up was overloaded it felt kind of okay enough on the front but feels much better now it is better balanced front/back. Uprating alone cannot change the load distribution so I am wondering if say a 4.6t chassis would would handle the front/back load distribution any different, unless it was heavier at the front to compensate?
I won't go there at all. Towing anything just does not appeal to me, if fact I only see it as a hindrance. There was a towbar fitted, alone it an extra put 60 kgs on the rear axle so I removed it.
I guess that the Alko chassis garage extension limit of 150 kgs is neither here nor there and more just to cover themselves. It's certainly has no issues carrying 250 kgs, or is that a good reason to change vehicles? So if uprating to 4t suffices then apart from the several hundred pounds for the paper exercise then I guess that I would just need to fit heavier load rated tyres on the back? If this MH was originally rated at 3850 kgs and then since downrated then is there an easier (cheaper) way to revert it? I think that some people have done this themselves without going through SV Tech?
That’s strange, my Phantom does not have an Alko chassis.
The problem going higher on the back axle could well be tyres. I have merc 15” alloy wheels and only Continental make tyres that will take the load in my size. Conti tech support are very good as were SVTech just finding info for me. Was I you I would definitely be getting advice from both of these before doing anything. I think you need ‘profession’ advice for this make and model. If yours has been changed to 16” wheels then you have a big choice of tyre make/models and it will be a lot easier.
If you do have 16” wheels can you tell me the make and source please
It's the standard Merc chassis but has a lower bolt on extension where the garage is. I have 15" alloy wheels with 112 load rated tyres that match the rear axle rating. I'll make some enquiries.
As a paper exercise I can go to 3850 kgs GVW with back axle to 2430 kgs, that might just about work when fully loaded including water. There is the option of moving the two leisure batteries to under the bench seat behind the driver's seat, though in reality they would only be at mid wheelbase but still likely take about 40 kgs off the rear axle. The tyres are new Conti's. Do I really need to carry the spare wheel as I have a plug kit and recovery cover?
It'll load up the MH and take it back to the weighbridge to see if uprating is viable.
I couldn’t find any tyres fir my rear axle til SVTech investigated for me. Conti are the only ones who do a suitable tyre for me, I couldn’t get a full winter tyre so settled on four seasons. It was previously on some Vancouver 1(?) that are no longer produced. You May be limited to the same as me due to tyres on the Phantom then.
I know the extension you mean, just in discussion with Armitage trailers about a tow bar/platform for mine to carry my handcycle.
I know the extension you mean, just in discussion with Armitage trailers about a tow bar/platform for mine to carry my handcycle.View attachment 47349
Have you double checked the data on the SVTech plate?
Yes! no doubt at all.
I had a wheel develop a small unseen crack and the tyre went down. There is a thread running now
switzerland-just-got-expensive.39917
Where I posted about it and another member also had a similar problem.
That is forgetting the fact that you can have an ordinary puncture.
When I had the wheel go down, it took three days to get a wheel!
Not good when on a tour!
58053-spare-wheel-cautionary-tale.html
I'd rather carry the spare for peace of mind as I did have a split valve though fortunately only a slow puncture on that occasion.
