Think there are lots of coffee fans here? These look a good deal from Amazon on a "Todays Deals" (so finish at Midnight).... https://amzn.to/2MtIaFJ
I have a kettle and use instant coffee - just as good and a lot cheaperProblem with pod machines is they don't steam milk. Have a look at the Bellman CX-25. A stovetop espresso which does steam milk too. I bought one and a mains powered good grinder over from Australia and it does a pretty good job, and on a gastop.
FWIW, I was an Aeropress fan, but my favourite motorhome coffee now comes courtesy of a Staresso -- a near-perfect shot of espresso without electricity. The crema from this machine is good enough to make a half-decent latte with hob-heated milk without needing frothing. OK, fifty quid and so not cheap, but it does make an excellent coffee and cheaper machines of this type are available if £50 seems too much!
Christmas list then. Sounds good.Aeropress just makes black coffee (without any crema). The ground coffee is mixed with hot water and the whole lot passed through the filter paper. OTOH, the Staresso holds the ground coffee in a 'portafilter' and water is forced through under pressure (15 to 25 bar), just like a regular espresso machine. The result is a beautiful crema on top of the shot -- it's proper espresso. The make a latte, I heat some millk to just below boiling on the stove, pour the milk into a preheated cup and then add the espresso. Sometimes I use a battery powered whisk to froth the milk before adding the espresso.
